13 years ago
Does VHDL has blocking and non blocking assignments?
I am a starter in VHDL (I only know Verilog before). I read some tutorial about VHDL. Now I am confused about assignment in VHDL. Does VHDL has blocking and non blocking assignments which are similar in Verilog?
In VHDL, there are two assignments "<=" and ":=". But it seems all signals are assigned through "<=", and variables are assigned by ":=". But in synthesised code, it seems always to use "<=" no matter combinational or sequential circuits. Does that mean in VHDL, there is not blocking and non-blocking assignements?
Hope someone who is familiar with VHDL can help me. Thanks very much!
    The real issue here is that signals can be used throughout a design and are usually registered, while variables can only be used within a VHDL process and take on immediate values. Often a variable is used to trigger another condition or state immediately within a process rather than waiting for the signal to be asserted on the next clock edge.
    Consider the case of a counter, declared with a record type, and used as a variable and then assigned as a signal (registered):
               Count the number of samples
    counter.start <= START;
    process(all)
    variable counterVal : integer range 0 to Nsamples;
    begin
        if HRST then
            counterVal  := 0;
            counter.val   <= (others => '0');
            counter.done <= '0';
        elsif rising_edge(MCLK) then
            if load then
                counterVal := Nsamples-1;
            elsif counter.start then
                if counter.val > 0  then
                     counterVal := counterVal - 1;
                else
                    counter.done <= '1';
                end if;
            end if;
        counter.val <= std_logic_vector(to_unsigned(counterVal,16));
        end if;
    end process;
    where the record type is declared as:
    type counterType is record
        start : std_logic;
        done  : std_logic;
        val   : integer range 0 to Nsamples-1;
    end record;
    signal counter : counterType;
    Conversely, consider the case of the same counter with signal type only.
    process(all) begin
        if HRST then
            counter.val  <= 0;
            if load then
                counter.val <= Nsamples-1;
                     counter.val <= counter.val - 1;
                else
                end if;
            end if;
        end if;
    end process;
    A VHDL variable assignment is working similarly to blocking procedural assignments in Verilog. They also work for synthesis. The main difference is the process local variable scope. "Global variables" exist in VHDL but are rarely supported for synthesis.
    Don't confuse Verilog blocking assignment with continuous assignments. The VHDL equivalent for the latter is a "<=" signal assignment in concurrent code.
    --- Quote Start ---
    But in following example:
    SIGNAL x1,x2,x3,f : STD_LOGIC;
    f<=(x1 AND x2) or x3;
    This code is actually same as in Verilog:
    assign f=(x1 && x2) || x3;
    and "<=" in VHDL (not registered) is actually same as "=" in Verilog, blocking assignment, right?
    Thanks!
    --- Quote Start ---
    --- Quote End ---
    What is mean of "continuous assignments"? Do you mean "unblocking assignment" in Verilog?
    And since local variable can be used outside process, even for pure combinational model as following example in VHDL:
    We still use "<=" instead of ":=". But in this example, "<=" in VHDL should be same as "=" in Verilog, right?
    Thanks!
    I did say "usually registered" as opposed to always registered. The code that you give below is an assignment, but not registered. In this case, the Verilog and VHDL are equal. -James
    --- Quote Start ---
    --- Quote Start ---
    Thanks!
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    I thought you are familiar with Verilog terminology. Continuous assignments is the Verilog term for assignments outside procedures (always, function, task etc).
    They are neither blocking nor non-blocking.
    VHDL is using <= for the same kind of assignments (assignments outside a process).
    Thanks very much, FvM. I am sorry, when I learned Verilog, I read some Chinese textbook, when you mentioned continuous assignment, I even didn't react what is that......
