13 years agoI did say "usually registered" as opposed to always registered. The code that you give below is an assignment, but not registered. In this case, the Verilog and VHDL are equal. -James
--- Quote Start --- --- Quote Start --- The real issue here is that signals can be used throughout a design and are usually registered, while variables can only be used within a VHDL process and take on immediate values. Often a variable is used to trigger another condition or state immediately within a process rather than waiting for the signal to be asserted on the next clock edge. But in following example: SIGNAL x1,x2,x3,f : STD_LOGIC; f<=(x1 AND x2) or x3; This code is actually same as in Verilog: assign f=(x1 && x2) || x3; and "<=" in VHDL (not registered) is actually same as "=" in Verilog, blocking assignment, right? Thanks! --- Quote End ---
