13 years ago
Demultiplexor Megafunction?
Hello, I am wondering if anybody created a custom megafunction that lets you make a demultiplexor. I am already aware that Altera provides a multiplexor megafunction, but it seems strange that they don't also have a demultiplexor too.
    It's fairly easy to create your own demux using HDL.
    Quartus has an option to create a symbol from an HDL module, which you can then use in your design.
    Here a small example in VHDL
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    entity demux1_4 is
    port (
          out0 : out std_logic;   --output bit
          out1 : out std_logic;   --output bit
           out2 : out std_logic;   --output bit
          out3 : out std_logic;   --output bit
           sel : in std_logic_vector(1 downto 0);
           bitin : in std_logic   --input bit
    end demux1_4;
    architecture Behavioral of demux1_4 is
    begin
    process(bitin,sel)
    begin
    out0 <= '0';
    out1 <= '0';
    out2 <= '0':
    out3 <= '0';
    case sel is
      when "00" => out0 <= bitin;
      when "01" => out1 <= bitin;
      when "10" => out2 <= bitin;
      when others => out3 <= bitin;
    end case;
    end process;
    end Behavioral;
    Will this be the proper way to make a 2bit 4 output demultiplexor?
    library IEEE;
    entity demux2_4 is
    port (
          out0 : out  std_logic_vector(1 downto 0);   --output bit
          out1 : out std_logic_vector(1 downto 0);   --output bit
           out2 : out std_logic_vector(1 downto 0);   --output bit
          out3 : out std_logic_vector(1 downto 0);   --output bit
           bitin : in  std_logic_vector(1 downto 0);   --input bit
    end demux2_4;
    architecture Behavioral of demux2_4 is
    begin
    process(bitin,sel)
    begin
    out0 <= '00';
    out1 <= '00';
    out2 <= '00':
    out3 <= '00';
    case sel is
    end case;
    end process;
    end Behavioral;
    Yes, it is.
    ( darn, the forum requires at least 10 characters in posts... )
    I tried compiling a 32 bit example of it, but I have an error:
    Error (10500): VHDL syntax error at testvhdl.vhd(12) near text ")";  expecting an identifier, or "constant", or "file", or "signal", or "variable"
    I am not sure what the issue is, but all I did was take your code and edit it to be a 32bit demultiplexor.
    library IEEE;
    entity demux32_4 is
    port (
          out0 : out  std_logic_vector(31 downto 0);   --output bit
          out1 : out std_logic_vector(31 downto 0);   --output bit
           out2 : out std_logic_vector(31 downto 0);   --output bit
          out3 : out std_logic_vector(31 downto 0);   --output bit
           sel : in std_logic_vector(31 downto 0);
           bitin : in  std_logic_vector(31 downto 0);   --input bit
    end demux32_4;
    architecture Behavioral of demux32_4 is
    begin
    process(bitin,sel)
    begin
    out0 <= '00000000000000000000000000000000';
    out1 <= '00000000000000000000000000000000';
    out2 <= '00000000000000000000000000000000':
    out3 <= '00000000000000000000000000000000';
    case sel is
    end case;
    end process;
    end Behavioral;
    the last entry in the port declaration should not have a ; on the end
    Also (I missed it) std_logic_vector constants use "", not ''.
    And you can replace
    with
    out0 <= (others => '0');
    to save some typing.
    Here is a larger demultiplexor that I did that demultiplexes multiple inputs. I currently have the error :
    Error (10309): VHDL Interface Declaration error in testvhdl.vhd(77): interface object "signedmultiply1" of mode out cannot be read. Change object mode to buffer.
    Error (10327): VHDL error at testvhdl.vhd(77): can't determine definition of operator ""<="" -- found 0 possible definitions
    Here is the code:
    library IEEE;
    entity alu_multiplicationordivisionchooser is
    port (
    unsigneddivide0 : out  std_logic_vector(31 downto 0);   --output bit_vector
    unsigneddivide1 : out std_logic_vector(31 downto 0);   --output bit_vector
    unsignedmultiply0 : out std_logic_vector(31 downto 0);   --output bit_vector
    unsignedmultiply1 : out std_logic_vector(31 downto 0);   --output bit_vector
    hiandlowregisterout : out std_logic_vector(63 downto 0); --output bit_vector
    gotoadder : out std_logic; --output bit
    subtract : out std_logic; --output bit
    sel : in std_logic_vector(2 downto 0);		--input bit_vector
    busin0 : in  std_logic_vector(31 downto 0);  --input bit_vector
    busin1 : in  std_logic_vector(31 downto 0);   --input bit_vector
    hiandlowregisterin : in std_logic_vector(63 downto 0) --input bit_vector
    end alu_multiplicationordivisionchooser;
    architecture Behavioral of alu_multiplicationordivisionchooser is
    begin
    process(busin0,busin1,sel)
    begin
      unsigneddivide0 <= (others => '0');
      unsigneddivide1 <= (others => '0');
      unsignedmultiply0 <= (others => '0');
      unsignedmultiply1 <= (others => '0');
      hiandlowregisterout <= (others => '0');
      gotoadder <= '0';
      subtract <= '0';
    case sel is
      when "000" => signedmultiply0 <= busin0, signedmultiply1
      <= busin1;
      when "001" => unsignedmultiply0 <= busin0, unsignedmultiply1
      <= busin1;
      when "010" => signeddivide0 <= busin0, signeddivide1
      <= busin1;
      when "011" => unsigneddivide0 <= busin0, unsigneddivide1
      <= busin1;
      when "100" => signedmultiply0 <= busin0, signedmultiply1
      <= busin1, hiandlowregisterout <= hiandlowregisterin ,gotoadder <= '1' ;
      when "101" => unsignedmultiply0 <= busin0, unsignedmultiply1
      <= busin1, hiandlowregisterout <= hiandlowregisterin ,gotoadder <= '1';
      when "110" => signedmultiply0 <= busin0, signedmultiply1
      <= busin1, hiandlowregisterout <= hiandlowregisterin, gotoadder <= '1', subtract <= '1';
      when others => out3 <= unsignedmultiply0 <= busin0, unsignedmultiply1
      <= busin1, hiandlowregisterout <= hiandlowregisterin ,gotoadder <= '1', subtract <= '1';
    end case;
    end process;
    end Behavioral;
    I am guessing the issue I have is with the case, and how I tell it to assign multiple outputs a value at the same time.
    EDIT: Nevermind I figured out the issue. I had to replace:
    case sel is
      <= busin1;
      <= busin1;
      <= busin1;
      <= busin1;
    end case;
    With:
    case sel is
      when "000" =>
      signedmultiply0 <= busin0;
      signedmultiply1 <= busin1;
      when "001" =>
      unsignedmultiply0 <= busin0;
      unsignedmultiply1 <= busin1;
      when "010" =>
      signeddivide0 <= busin0;
      signeddivide1 <= busin1;
      when "011" =>
      unsigneddivide0 <= busin0;
      unsigneddivide1 <= busin1;
      when "100" =>
      signedmultiply1<= busin1;
      hiandlowregisterout <= hiandlowregisterin;
      gotoadder <= '1' ;
      when "101" =>
      gotoadder <= '1';
      when "110" =>
      gotoadder <= '1';
      subtract <= '1';
      when others =>
      unsignedmultiply1<= busin1;
      gotoadder <= '1';
      subtract <= '1';
    end case;
