I tried compiling a 32 bit example of it, but I have an error:
Error (10500): VHDL syntax error at testvhdl.vhd(12) near text ")"; expecting an identifier, or "constant", or "file", or "signal", or "variable"
I am not sure what the issue is, but all I did was take your code and edit it to be a 32bit demultiplexor.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity demux32_4 is
port (
out0 : out std_logic_vector(31 downto 0); --output bit
out1 : out std_logic_vector(31 downto 0); --output bit
out2 : out std_logic_vector(31 downto 0); --output bit
out3 : out std_logic_vector(31 downto 0); --output bit
sel : in std_logic_vector(31 downto 0);
bitin : in std_logic_vector(31 downto 0); --input bit
end demux32_4;
architecture Behavioral of demux32_4 is
begin
process(bitin,sel)
begin
out0 <= '00000000000000000000000000000000';
out1 <= '00000000000000000000000000000000';
out2 <= '00000000000000000000000000000000':
out3 <= '00000000000000000000000000000000';
case sel is
when "00" => out0 <= bitin;
when "01" => out1 <= bitin;
when "10" => out2 <= bitin;
when others => out3 <= bitin;
end case;
end process;
end Behavioral;
