sun_tak
2 years agoDDRIO IP block is not placed in IOC.
I'm using Quartus prime 20.1.1.
When using Arria 10 to capture data from an ADC with a DDR type data output that can sample at 160MHz, when I used DDRIO IP, the DDRIO circuit was not placed in the IOC. Please tell me the cause and countermeasure.
- AqidAyman_Altera
Thank you for reaching out FPGA community.
For your issue, I need to understand more about your design,
Can you share your top-level diagram of the design?
I also need clarification on the OIC. Can you elaborate more on that?
Aqid
- sun_tak
The figure below shows the data input section from the ADC. The data and clock from the ADC are received via LVDS.The figure below shows one bit of "ad_d0_[6..0]" shown in the figure above when viewed using a chip planner.The above circuit is not placed in the "DDIO IN" block at the bottom right of the chip planner.How can I place it in the "DDIO IN" block at the bottom right of the chip planner?best regards.
- sun_tak
I solved the problem. I confirmed that the IOC has a DDR element other than the DDRIN block. - AqidAyman_Altera
I'm glad the issue you are facing is solve. May I know if you need any other support on this?
Aqid
- sun_tak
Dear Aqid.
Thank you for your support. There is nothing else.
- AqidAyman_Altera
Thank you for the confirmation. I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response.
p/s: If you feel the support is excellence, feel free to rate "Very Satisfied" once you get the evaluation survey. I appreciate your kindness.
