sun_tak
2 years agoDDRIO IP block is not placed in IOC.
I'm using Quartus prime 20.1.1. When using Arria 10 to capture data from an ADC with a DDR type data output that can sample at 160MHz, when I used DDRIO IP, the DDRIO circuit was not placed in the I...
sun_tak
2 years agoThe figure below shows the data input section from the ADC.
The data and clock from the ADC are received via LVDS.The figure below shows one bit of "ad_d0_[6..0]" shown in the figure above when viewed using a chip planner.The above circuit is not placed in the "DDIO IN" block at the bottom right of the chip planner.
How can I place it in the "DDIO IN" block at the bottom right of the chip planner?best regards.
