sun_tak
2 years agoDDRIO IP block is not placed in IOC.
I'm using Quartus prime 20.1.1. When using Arria 10 to capture data from an ADC with a DDR type data output that can sample at 160MHz, when I used DDRIO IP, the DDRIO circuit was not placed in the I...
AqidAyman_Altera
2 years agoHi,
Thank you for reaching out FPGA community.
For your issue, I need to understand more about your design,
Can you share your top-level diagram of the design?
I also need clarification on the OIC. Can you elaborate more on that?
Aqid
