zjj's avatar
zjj
1 day ago
dcfifo problem
In our project, we instantiate the parameterizable DCFIFO primitive provided by Altera. The design passes simulation verification without issues; however, mismatches occur between written and read data from the DCFIFO by signalTAP during board-level testing , which consequently causes driver loading failures.
fpga device:agilex7 with quartus pro25.3
dcfifo wr_clk: 450M
dcfifo rd_clk: 416M
the instantiate example:
is there better suggestion?
  • sstrell's avatar
    sstrell
    This could also be a timing issue.  Is your design closing timing?
  • BCuze's avatar
    BCuze
    I'm curious about how you test the discrepancy.
    From which clock does Signaltap run ? IMO, you should have two STPs, one on each clock.
    Did you try pushing PRBS data and check what comes out ? Easier than STP IMO.
  • ShengN_altera's avatar
    ShengN_altera
    Possible provide simulation waveform and signal tap waveform for taking a look? Or possible provide design for taking a look?
