Creating BSF strips parentheses from output signal size
When I attempt to generate a BSF using the following system verilog code, Quartus 20.1 Prime Lite is stripping the parentheses from the calculation of the output signal size. This results in an incorrect calculation of the size of the output (it is doing 4*2*8+24 = 88). However, it only does this on the BSF (see first attachment). Inside of my module, the size of the signal is correctly calculated as 4*2*(8+24) = 256.
Is this expected behavior for using BSF and BDF files? It's been several years and versions of Quartus since I used a BDF (>10 yrs) rather than doing everything in HDL.
If I use a text editor to edit the BSF file I can change the text to include parentheses and my system compiles (see second attachment). However, as soon I regenerate the BSF it overwrites the old text and is incorrect again.
module sync_adc_data #( parameter integer STREAM_COUNT = 4, parameter integer CHANNELS_PER_STREAM = 2, parameter integer HEADER_WIDTH = 8, parameter integer DATA_WIDTH = 24 ) ( input clk_i, input rst_i, output logic [((STREAM_COUNT * CHANNELS_PER_STREAM * (HEADER_WIDTH + DATA_WIDTH)) - 1) : 0] word_o ); endmodule : sync_adc_data
- Nurina
Sometimes there are problems with generating block symbols from HDL and vice versa. I've reproduced your error and am reporting this issue to engineering.
Nurina
- Nurina
I'd just like to update you on this matter. Engineering is currently investigating the root cause of the problem.
Nurina
- 07dshaffer
Thank you for the update.
- Nurina
Engineering has investigated root cause. However, they are now focusing feature enhancement/bug fixing on Pro edition. For standard, they will put it as lower priority. This fix will take some time . We are sorry to inform this.With that, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.Regards,Nurina - 07dshaffer
Okay, thank you for looking into the issue. If I leave this issue open, can you let me know when this bug is fixed?
- Nurina
Yes, I can do that. Please note that it will take a while to be fixed.
Nurina
- Nurina
Engineering has made preliminary plan to fix this issue in Quartus Standard version 21.1 which will be released around September. Until then you will have to use the workaround of editing the symbol after regenerating it.
With that being said, I will put this case to a close pending. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
