07dshaffer
5 years agoCreating BSF strips parentheses from output signal size
When I attempt to generate a BSF using the following system verilog code, Quartus 20.1 Prime Lite is stripping the parentheses from the calculation of the output signal size. This results in an incor...
Nurina
5 years agoHi,
Sometimes there are problems with generating block symbols from HDL and vice versa. I've reproduced your error and am reporting this issue to engineering.
Nurina
