07dshaffer
5 years agoCreating BSF strips parentheses from output signal size
When I attempt to generate a BSF using the following system verilog code, Quartus 20.1 Prime Lite is stripping the parentheses from the calculation of the output signal size. This results in an incor...
07dshaffer
5 years agoOkay, thank you for looking into the issue. If I leave this issue open, can you let me know when this bug is fixed?
