8 years agoCreating a new IP component with VHDL design using a customized library
I am trying to create a new component using Component Editor of Qsys. Actually, the top level design of the new component calls a library "Lib" that I have created and uses a pckage defined in this library. So, in the beginning of the top level design I have: library Lib; use Lib.package.all; My question is how to tell the Component Editor to take into consideration the library Lib? Shall I add all the library files in the step of specifing the component files? Thank you,2 Replies
I have added all the files if the library "Lib" but I have the same error message. I think that the tool doesn't like user libraries. With Quartus I was able to add all the design files (in VHDL) of "Lib" and to define them as a library then the compilation of the top level design in VHDL was successful. So what I am looking for is how to do the same with QSYS because I can add the files but I don't know how to declare them as library "Lib".
Thanks. - Altera_Forum
Yes, just like if you were to synthesize this in Quartus, you have to add all of your files to the Files tab of the Component Editor.
