Kocsonya's avatar
Kocsonya
3 months ago
Possible Quartus 24.1 bug?
Here is the code:
interface myif
parameter int W = 1
typedef struct packed { logic [W-1:0] x; } MYSTRUCT;
MYSTRUCT s;
modport src ( output s );
modport dst ( input s );
endinterface
module top;
myif #( .w( 5 ) ) test_if();
test test_module
.foo( test_if )
endmodule
module test
myif.dst foo
typedef foo.MYSTRUCT MYSTRUCT_COPY;
$info( "%0d %0d", $bits( foo.MYSTRUCT ), $bits( MYSTRUCT_COPY ) );
MYSTRUCT_COPY q;
assign q = foo.s;
endmodule
Surprisingly, the info message will print "5 1" instead of "5 5". And for the assign Quartus will complain that it had to crop the 5 bit wide foo.s to match the 1 bit wide q.
When processing the typedef, Quartus uses the interface definition's default W value instead of the actual value of the actual interface port. I believe that, according to the standard, that is not the expected behaviour.
  • Hi Kocsonya,
    Could you please share the full Quartus warning/error message that is being reported?
    In the meantime, could you also try compiling the design with the latest Quartus version 26.1 and let us know whether the behavior is still reproducible?
    If the issue persists in Quartus 26.1, would it be possible to share a minimal reproducible test case?
    Thank you.
    ZiYingE_Altera
  • Kocsonya's avatar
    Kocsonya
    This particular problem does not exist, or more precisely, not in this form, in 26.1.
    I create a new thread which demonstrates the 26.1 bug, which is related to this one. That one has the exact test source and project file an everything to produce the bug.
    • ZiYingE_Altera's avatar
      ZiYingE_Altera
      Hi Kocsonya,
      Thank you for the update.
      Since the discussion is already being continued in the new thread, I will close this discussion for now.
      Thanks again for engaging with us!
      ZiYingE_Altera
