16 years agoControlling the setting of IO pad delays
I have a design which uses a PLL to create an internal copy of an external clock used to interface a processor to a Cyclone II. The aim is to optimise the transfers to and from the processor by ensuring data is centred in the "eye", the usual approach. All the signals to and from the FPGA are registered in the IO pads using "fast" commands so the timing margins should be dependent only on the programmable input and output delays in the pads and the PLL phase shift (boards track delays are taken into account in the SDC constraint values).
I've done offline calculations which suggest the optimum values would be 1250ps for phase shift (the numbers don't matter, just for example) with the output delay on step 1 (range 0-1) and the input delay on step 4 (range 0-7) based on min and max device parameters which are the extremes over both the slow and fast models. Setting the phase shift in the Megawizard is trivial but on synthesis Quartus choses delays of 0 and 2 respectively. This still gives me positive slack by my calculations (so not too much of a problem on this project) but about half of what I would expect with the optimum values. First question: does Quartus try to centre the sample point in the eye or does it have some other strategy? If so, second question, does it use only one speed model, e.g. slow. I have set the "Enable multicorner timing analysis during compilation" option under the Timequest Timing Analyzer" settings but I expect that only affects reporting. The problem I foresee here is that, in a tight design, it might by centered for a slow chip but have negative slack on a fast one whereas more balanced choice might be able to achieve a smaller positive slack over the whole range of PVT. Third question: if I choose to force my values on the design, is there a way to set these pad delays in the QSF or SDC? I have been able to fix them manually using the Resource Property Editor and then export the change as a TCL file but integrating and maintaining that as part of the design flow could be tricky to manage unless I can get Quartus to call the file at the appropriate stage. George
