16 years ago --- Quote Start --- Thanks for that, it's a great help. The device is a Cyclone II. I have attached a graphic of the editor where I tried making the change, you can see it turns blue at the bottom of the table. I had thought that making changes via the various editors stored the info in the QSF but that doesn't seem to be the case here, after making this change, a "save" stores an ECO and causes the fitter to be run but there was no difference in the QSF after I closed Quartus. We have configuration control of the QSF and SDC files but if the ECO data is stored elsewhere, we would need to include the relevant file(s). --- Quote End --- Hi, for Cyclone II unfortunately I have no solution. BTW: A far as I know ECO change will be never stored in the QSF od SDC file automatically !
