16 years ago --- Quote Start --- OK, thanks. I'm rebuilding with the multi-corner option on now which may persuade Quartus to choose the same values as I calculated. Thanks again for your help. George --- Quote End --- Hi George, good news. I found the setting for the assignment editor in order to set the delays for CycloneII. I have the project attached. For the input you have a valid range from 0 - 7, for the output 0-1. For the real delays look into the resource property editor. You can check the setting under: Compilation report -> Fitter -> Resource section -> Delay Chain summary Kind regards GPK
