Constraining SPI flash lines
- How do I constrain MISO, MOSI & SCLK signals?
- How to configure set_input_delay constraint for MISO?
- How to configure set_output_delay constraint for MOSI?
- Do I need to constrain SCLK as well?
- Where to find flash device Tco?
- KennyT_altera
Here is some example that you can try:
# === Clocks ===
# 100 MHz board/system clock (ns, not MHz)
create_clock -name CLK_IN -period 10.000 [get_ports {clk}]
# PLL output at 100 MHz (adjust instance path as needed)
create_generated_clock -name PLL_100M \
-source [get_ports {clk}] \
[get_pins {corepll_inst|altpll_component|auto_generated|pll1|clk[0]}]
# Clock on the SPI SCLK output pin (this is the reference we'll use)
# Use the PLL output (or the clock that actually feeds your SCLK generator) as -source
create_generated_clock -name SCLK_FPGA \
-source [get_pins {corepll_inst|altpll_component|auto_generated|pll1|clk[0]}] \
[get_ports {SCLK1}]
# (If your SCLK port is QSPI_CLK, change {SCLK1} to {QSPI_CLK})
# === Board delays & flash timing (example numbers; replace) ===
# PCB delay from FPGA pins to device pins (ns)
set sclk_board 0.80
set mosi_board 0.70
set miso_board 0.95
# Relative skews (ns)
set skew_out [expr {$sclk_board - $mosi_board}] ;# SCLK vs MOSI at the device
set skew_in [expr {$miso_board - $sclk_board}] ;# MISO vs SCLK at the FPGA
# Flash datasheet timing (ns) — replace with your part’s values
set t_su 2.5 ;# flash input data setup to SCLK sampling edge
set t_h 1.0 ;# flash input data hold from SCLK sampling edge
set tco_min 1.5 ;# flash SCLK→MISO earliest
set tco_max 6.0 ;# flash SCLK→MISO latest
# === MOSI (FPGA -> Flash) ===
# If the flash samples MOSI on RISING SCLK: (SPI mode accordingly)
set_output_delay -clock [get_clocks SCLK_FPGA] \
-max [expr {$t_su + $skew_out}] [get_ports {MOSI1}]
-min [expr {-$t_h + $skew_out}] [get_ports {MOSI1}]
# If the flash instead samples on FALLING SCLK, add -clock_fall to BOTH lines above:
# set_output_delay -clock [get_clocks SCLK_FPGA] -clock_fall -max ...
# set_output_delay -clock [get_clocks SCLK_FPGA] -clock_fall -min ...
# === MISO (Flash -> FPGA) ===
# If the flash launches MISO on the OPPOSITE edge to the MOSI sampling edge (typical),
# use -clock_fall. If it launches on rising, omit -clock_fall.
set_input_delay -clock [get_clocks SCLK_FPGA] -clock_fall \
-max [expr {$tco_max + $skew_in}] [get_ports {MISO1}]
-min [expr {$tco_min + $skew_in}] [get_ports {MISO1}]
# === Good practice ===
derive_pll_clocks
- derive_clock_uncertainty
Notes:
Don’t put set_output_delay on SCLK1 itself—SCLK is the reference clock, not data.
Use -clock_fall on MOSI/MISO constraints if your SPI mode uses the falling edge for sampling/launching.
Replace {SCLK1}, {MOSI1}, {MISO1} (or {QSPI_CLK}) and the PLL path with your actual names, and plug in your flash datasheet timings and measured PCB delays.
- KennyT_altera
Not sure if you have further question for the above? If no, we shall close this thread.
- KennyT_altera
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
