Compilation on quartus tool fails for encrypted verilog and verilog header files
I am trying to compile the encrypted design [generated by synopsys designware core]. This design is encrypted.
Quartus tool is not able to compile this encrypted design.
Quartus Tool version used: 22.3
Below is the error displayed during compilation:
Error(13411): Verilog HDL syntax error at DW_apb_i2c_intctl.vp(1) near text ?', expecting 'class
Below are experiments done:
1] RTL files those are encrypted one had .v extension. Tried removing this and added as .vp
2] Added below code in .qsf file:
set_global_assignment -name SYSTEMVERILOG_FILE /home/projects/ace/build/ace_agib027_2023_01_05_04_43_47/design/dw_i2c/i2c/src_enc/DW_apb_i2c_intctl.vp
Still, the error is shown.
Can you guide, how to compile the encrypted design files using Quartus tool ?
Sneha
- RichardT_altera
I assumed that the third-party tool support IEEE1735.
Does the files encrypted using the Quartus public key? File encryption with a third-party tool requires the public encryption key.
You may checkout this video on how-to:
https://www.youtube.com/watch?v=jr8oNk7I2SQ
Richard Tan
- sneha_wagh
Hi Richard,
I went through the document and video. It shows how to encrypt and decrypt the design using Intel Key.
My concern is different. The third party IP is from synopsys. It is already encrypted. So the Quartus is not able to compile it.
With Xilinx Vivado, in such cases, we can launch the Synplify pro. using Vivado and then such RTL which is encrypted one can be compiled and synthesized for a specific FPGA target family. Once synthesis is done, the netlist is used further in the main flow for compilation.
So I think similar process could be there with Quartus tool but I was not able to find the same ?
Is there an option to launch the third party synthesis process with third party tool such as synplify pro and target the process for a specific Intel FPGA family ? Then I could be at-least generate the netlist and then use it in main compilation flow.
Sneha
- RichardT_altera
Could you try to set the synthesis tool to Synplify Pro in Quartus? Go to Setting > EDA Tool Settings > Design entry/ synthesis > Synplify Pro.
Usually third party encryption tool will need Quartus public key to encrypt then the Quartus can compile it.
The documentation that I found about Synplify support:
https://www.intel.com/content/www/us/en/docs/programmable/683122/18-1/synopsys-synplify-support.html
Richard Tan
- RichardT_altera
May I know know does my latest suggestion helps?
Richard Tan
p.s. Please do expert delay in response due to lunar new year.
- sneha_wagh
Hi Richard,
I tried all the steps that you had mentioned.
The tool is not able to find where the synplify pro is located.
I do not have synplify pro license. We are checking whether can we have evaluation license to try out. IT team is working on it.
Also I had raised query related to public Key to be used on intel support platform. But they guided me that I cannot use the support platform to get the key.
To whom should I contact or can I request you to obtain the public key ?
Sneha
- sneha_wagh
Hi Richard,
As evaluation license borrowing of Synplify is in process, I wanted to check that where we should mention in Quartus tool about this synplify tool installation path ?
In above document, it is mentioned that:
To set up the Intel® Quartus® Prime software to run the Synplify software, do the following:
- On the Tools menu, click Options.
- In the Options dialog box, click EDA Tool Options and specify the path of the Synplify or Synplify Pro software under Location of Executable.
We are using Quartus Prime Software version 22.3
I was able to see Tools menu -> Options.
But did not find out "EDA Tool Options".
Sneha
- RichardT_altera
We have removed the EDA Tool Option GUI in Quartus Pro.
You may checkout this user guide on the Synplify* 2.2. Design Flow
https://www.intel.com/programmable/technical-pdfs/683122.pdf
Richard Tan
- RichardT_altera
Do you need further help in regards to this case?
Richard Tan
- sneha_wagh
Hi Richard,
We can close this case.
Sneha
- RichardT_altera
Thank you for response.
I hope that your question has been addressed, with that, I now transition this thread to community support.
Richard Tan
