11 years agoCode Check - Traffic Simulation
Hey guys,
My program seems to be stuck in the first step of the State Machine and I cannot for the life of me figure out why, I suspect a problem with the counter? Any help is appreciated. counter: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library UNISIM; use UNISIM.VComponents.all; entity Counter is Port ( reset : in STD_LOGIC; clear : in STD_LOGIC; clock : in STD_LOGIC; counto : out STD_LOGIC_vector (9 downto 0); -- count output finish : out STD_LOGIC finish2 : out STD_LOGIC ); end Counter; architecture Behavioral of Counter is signal count_i: std_logic_vector (9 downto 0); -- 9 bit timer appropriate for 100Hz required speed signal cen: std_logic; -- count enable begin counto <= count_i; cen <= '1'; -- start count enable process (clear, reset, clock) begin -- begin process if (reset = '1') then -- if reset begin count to as if EW car has been there for a 'long time' count_i <= "1000000001"; elsif rising_edge (clock) then -- on rising edge of clock if (clear = '1') then cen <= '1'; -- if cleared begin counting count_i <= "0000000001"; elsif (cen = '1') then -- when count is enabled count up from 000000001 count_i <= count_i + "000000001"; if (count_i >= "1000000001") then -- if minimum time is reached stop counting and wait for an input cen <= '0'; finish <= '1'; if (count_i >= "0000100001") then cen <= '0'; finish2 <= '1'; end if; end if; end if; end process; end architecture Behavioral; state machine
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library UNISIM; use UNISIM.VComponents.all; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity StateMachine is Port ( clock : in STD_LOGIC; reset : in STD_LOGIC; carNS : in STD_LOGIC; carEW : in STD_LOGIC; finish : in STD_LOGIC; pedNS : in STD_LOGIC; pedEW : in STD_LOGIC; pedo : out STD_LOGIC; clearo : out STD_LOGIC; lightsEW : out STD_LOGIC_VECTOR (1 downto 0); -- controls EW lights lightsNS : out STD_LOGIC_VECTOR (1 downto 0); -- controls NS lights pedcount : in STD_LOGIC_vector (7 downto 0)); end StateMachine; architecture Behavioral of StateMachine is type StateType is (greenNS, amberNS, redNS, greenEW, amberEW, redEW); signal state, nextState: StateType; begin SynchronousProcess: -- execute all at once process (clock) begin -- only list clock, program auto fills required variables nextState <= greenEW; -- start at green EW light lightsEW <= "10"; -- car EW light green (10) lightsNS <= "00"; -- car NS lights red (01) case state is when greenEW => -- when car EW is green (10) lightsEW <= "10"; -- Good up to here if (finish = '1') then -- if count is above 1000000001 and a car is present on NS road then set EW light to amber if (carNS = '1') then nextState <= amberEW; clearo <= '1'; -- begin amber state, stop counting else -- else remain green for EW nextState <= greenEW; end if; end if; if (pedNS = '1') then -- if NS pedestrian button pressed nextState <= amberEW; clearo <= '1'; -- begin amber state, stop counting else nextState <= greenEW; -- else remain green for EW end if; when amberEW => -- when amber set lights to amber (01) lightsEW <="01"; if (finish2 = '1') then -- if count is above 0000100001 and a car is present on NS road then set EW light to red nextState <= redEW; clearo <= '1'; -- begin red state, stop counting end if; when redEW => -- when red set lights to red (00) lightsEW <="00"; if (finish = '1') then -- if count is above 1000000001 move to green state for NS road nextState <= greenNS; end if; when greenNS => -- when in green state set NS car lights to green (10) lightsNS <="10"; if (finish = '1') then -- if count is above 1000000001 and a car is present on EW road then set NS light to amber if (carEW = '1') then -- if car present on EW road, nextState <= amberNS; clearo <= '1'; -- begin amber state, stop counting else nextState <= greenNS; -- else stay green end if; end if; if (pedEW = '1') then -- if EW pedestrian button pressed nextState <= amberNS; -- begin amber state, stop counting clearo <= '1'; else nextState <= greenNS; -- else remain green for NS end if; when amberNS => lightsNS <="11"; -- set NS lights to amber (11) if (finish2 = '1') then -- if count is above 0000100001 set NS lights to red nextState <= redNS;clearo <= '1'; end if; when redNS => lightsNS <="00"; if (finish = '1') then -- if count is above 1000000001 set NS lights to red nextState <= greenEW; end if; end case; end process; process (reset,clock) begin -- begin process if (reset='1') then -- if reset go to state greenEW (first state) state <= greenEW; elsif rising_edge(clock) then -- else, if on a rising clock edge move to next state state <= nextState; clearo <='1'; -- stop counting end if; end process; end architecture Behavioral;
