11 years agoMy question is: where is the testbench code?
Second question: why have you put clock in the state machine sensitivity list, when it is clearly not a clocked process? and the comment is worrying, because it shows lack of understanding of VHDL: process (clock) begin -- only list clock, program auto fills required variables Quartus wont do any auto-filling for you. It will throw warnings about missing signals (note - not variables), but it ignores sensitivity lists, so you wont see a "problem". If you had a testbench, you would see that you would get many problems. thurdly - you state machine proces produces latches - these are not recommended. You need to assign all signals in ALL cases in an asynchronous process (it is not synchronous, it is asynchronous, despite your comments).
