Mikexx
2 years agoClock missing from Timing Analyzer - Report Setup Summary
I have a clock mux along the lines in "ug-qps-03-design-recommendations.pdf" I have set the output clock to be a Global Clock in the Assignment Editor and I give it's minimum period in the sdc file....
ShengN_altera
2 years agoHi,
I guess you have create clock for your input clock and derive the pll clock.
In the timing analyzer, can you leave the From clock and To clock blank.
Then in Targets section, in either the From or To column search the HDMI_TX_CLK i think may be using get_keepers.
After that report timing.
Sheng
- Mikexx2 years ago
Sorry for the late reply. Holidays get in the way of work, plus a rush project.
If I go to:
Timing Analyzer -> Constraints -> Set Maximum Delay -> From -> click on 3 dots
Collection -> get_clocks
Filter -> *HDMI_TX_CLK* (with asterisks)
List
I can see 1 match of HDMI_TX_CLK
Hope this helps.
