10 years ago
clock delay
Hi everyone,
I'm asking how can I produce a time delay
for exemple, I want to put a pin to the ground, then 1s later, I wanna put the second pin to the ground
I was exemple of program like after or wait. But it seems I used them badly, it doesn't really work with me
Could anyone help me please?
thank you very much
    wait statements are only for simulation. If you want to synthesize your design you will have to create counters, which you check and based on their value you either bring a signal high or low.
    Here is the synthesizeable code would help :
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    entity delay_gen is
    nreset : in std_logic;
    clock : in std_logic;
    pin1 : out std_logic;
    pin2 : out std_logic
    end entity delay_gen;
    architecture behav of delay_gen is
    type simple_fsm is (st1, st2);
    signal state_trans : simple_fsm;
    signal sec_count : std_logic_vector(10 downto 0);
    begin
    delay_proc: process(nreset,clock)
    begin
    if(nreset = '0') then
    state_trans <= st1;
    sec_count <= (others=>'0');
    elsif(rising_edge(clock)) then
    case state_trans is
    when st1 =>
    pin1 <= '0'; -- Set to ground
    sec_count <= x""; --Put the counter value w.r.t to the clock you select
    state_trans <= st2;
    when st2 =>
    if(sec_count > 0) then --1 second counter has not elapsed
    sec_count <= sec_count - 1; --decrement counter
    state_trans <= state_trans; --continue to be there in same state
    else
    pin2 <= '0'; -- Set second pin to ground
    state_trans <= st1;
    end if;
    when others =>
    sec_count <= x"" --Put the counter value w.r.t to the clock you select
    pin1 <= '1'; --Keep pin1 at VCC
    pin2 <= '1'; --Keep pin1 at VCC
    end case;
    end if;
    end process delay_proc;
    end architecture behav;
    Thank you for your replying, but it seems I met some problem with that code, what should I put instead of x""? I put 1000 instead and it doesn' work
    --- Quote Start ---
    --- Quote End ---
    You need to put the value that will divide the clock to give you 1 second pulses. So if you have a 50mhz clock, you need to set the value to 50000000 (x"02FAF080") - you would also need a larger counter.
