10 years agoclock delay
Hi everyone, I'm asking how can I produce a time delay for exemple, I want to put a pin to the ground, then 1s later, I wanna put the second pin to the ground I was exemple of program like af...
10 years agowait statements are only for simulation. If you want to synthesize your design you will have to create counters, which you check and based on their value you either bring a signal high or low.
