10 years agoclock delay
Hi everyone, I'm asking how can I produce a time delay for exemple, I want to put a pin to the ground, then 1s later, I wanna put the second pin to the ground I was exemple of program like af...
10 years ago --- Quote Start --- Thank you for your replying, but it seems I met some problem with that code, what should I put instead of x""? I put 1000 instead and it doesn' work --- Quote End --- You need to put the value that will divide the clock to give you 1 second pulses. So if you have a 50mhz clock, you need to set the value to 50000000 (x"02FAF080") - you would also need a larger counter.
