10 years agoclock delay
Hi everyone, I'm asking how can I produce a time delay for exemple, I want to put a pin to the ground, then 1s later, I wanna put the second pin to the ground I was exemple of program like af...
10 years agoHere is the synthesizeable code would help :
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity delay_gen is ( nreset : in std_logic; clock : in std_logic; pin1 : out std_logic; pin2 : out std_logic ); end entity delay_gen; architecture behav of delay_gen is type simple_fsm is (st1, st2); signal state_trans : simple_fsm; signal sec_count : std_logic_vector(10 downto 0); begin delay_proc: process(nreset,clock) begin if(nreset = '0') then state_trans <= st1; sec_count <= (others=>'0'); elsif(rising_edge(clock)) then case state_trans is when st1 => pin1 <= '0'; -- Set to ground sec_count <= x""; --Put the counter value w.r.t to the clock you select state_trans <= st2; when st2 => if(sec_count > 0) then --1 second counter has not elapsed sec_count <= sec_count - 1; --decrement counter state_trans <= state_trans; --continue to be there in same state else pin2 <= '0'; -- Set second pin to ground state_trans <= st1; end if; when others => sec_count <= x"" --Put the counter value w.r.t to the clock you select pin1 <= '1'; --Keep pin1 at VCC pin2 <= '1'; --Keep pin1 at VCC end case; end if; end process delay_proc; end architecture behav;
