10 years agoclock delay
Hi everyone, I'm asking how can I produce a time delay for exemple, I want to put a pin to the ground, then 1s later, I wanna put the second pin to the ground I was exemple of program like af...
10 years agoThank you for your replying, but it seems I met some problem with that code, what should I put instead of x""? I put 1000 instead and it doesn' work
