VerilogStudent
6 years agoChecker not found - Verilog.
Hey i wrote this code in Verilog.
This is the Code:
module shift_register(write,s_in,clk,d,s_out,p); input write,clk; input [3:0] d; input [11:0] s_in; output reg s_out; output reg [3:0] p; wire mux_1,mux_2,mux_3,mux_4,dff_1,dff_2,dff_3,dff_4; // 8 wires mux2_1 mux1(.s(s_in),.d(d[3]),.w(write),.z(mux_1)); // mux1 D_FlipFlop dff1(.d(mux_1),.clk(clock),.q(dff_1)); // DFlipFlop1 always@(posedge clk) begin p[3]<=dff_1; end mux2_1 mux2(.s(dff_1),.d(d[2]),.w(write),.z(mux_2));// mux2 D_FlipFlop dff2(.d(mux_2),.clk(clock),.q(dff_2)); // DFlipFlop2 always@(posedge clk) begin p[2]<=dff_2; end mux2_1 mux3(.s(dff_2),.d(d[1]),.w(write),.z(mux_3));// mux3 D_FlipFlop dff3(.d(mux_3),.clk(clock),.q(dff_3)); // DFlipFlop3 always@(posedge clk) begin p[1]<=dff_3; end mux2_1 mux4(.s(dff_3),.d(d[0]),.w(write),.z(mux_4));// mux4 D_FlipFlop dff4(.d(mux_4),.clk(clock),.q(dff_4)); // DFlipFlop4 always@(posedge clk) begin p[0]<=dff_4; s_out<=dff_4; end endmodule
and this is the Testbench:
module shift_register_testbench(); wire write,clk; input [3:0] d; input [11:0] s_in; output reg s_out; output reg [3:0] p; initial begin d[3:0] = 1'b1; write = 1'b0; s_in[0] = 1'b1; #10; s_in[1] = 1'b0; #10; s_in[2] = 1'b0; #10; s_in[3] = 1'b1; #10; s_in[4] = 1'b0; #10; s_in[5] = 1'b0; write = 1'b1; #10; s_in[6] = 1'b1; write = 1'b0; #10; s_in[7] = 1'b0; #10; s_in[8] = 1'b1; #10; s_in[9] = 1'b1; #10; s_in[10] = 1'b1; #10; s_in[11] = 1'b0; #10; shift_register SRTB(.write(write),.s_in(s_in[11:0]),.clk(clk),.d(d[3:0]),.s_out(s_out),.p(p[3:0])); end endmodule
And when I`m try to run the testbench this problem appear:
how can i fix it?THNX!
- sstrell
Where is your shift register HDL file located? Is it in the same directory as the testbench? I think the issue is ModelSim is simply not seeing the file. Make sure you "Change Directory" in ModelSim to point to the location of the code.
#iwork4intel
- SyafieqS
Hi Naor,
Make sure your HDL and testbench in same directory when you simulating the design. The directory in Modelsim is same as the path where your hdl and tb files.
- VerilogStudent
Yes i fixed it. Thanks. Close case please.
