VerilogStudent
6 years agoChecker not found - Verilog.
Hey i wrote this code in Verilog.
This is the Code:
module shift_register(write,s_in,clk,d,s_out,p);
input write,clk;
input [3:0] d;
input [11:0] s_in;
output reg s_out;
output reg [3:0] p;
sstrell
6 years agoWhere is your shift register HDL file located? Is it in the same directory as the testbench? I think the issue is ModelSim is simply not seeing the file. Make sure you "Change Directory" in ModelSim to point to the location of the code.
#iwork4intel
