11 years agoAsync FIFO 2 Clock code advice - VHDL
Hi all,
I want to ask if someone can advice me an Async FIFO with 2 clocks code in VHDL that works. I know Xilinx provide already build in FIFO IP core, but since I want possibility to migrate my code also to other devices I need a code that I can easy port. Thank you.4 Replies
Altera have a DC fifo megafunction. You can generate one with the Megawizard/ipcatalogue or manually instatiate one yourself (if you are familiar with using the altera_mf_components library and reading the documentation).
If you need code that is compilable on both altera and Xilinx, you have 2 options: 1. Make a wrapper around the dc fifo/xilinx fifo that uses a generic to differentiate the manufacturere) 2. Write your own DC fifo (you need to be really careful how you cross the clock domains). The first option may be the easiest. - Altera_Forum
Thanks for you answer. But I need the possibilty to use this code also with devices not from Xilinx or Altera. The second option have a problem that I can't really know if my code will be without errors or optimized. So I ask if someone have an opensource Async FIFO.
You could try opencores.org
There's much on the web on this.
E.g. http://www.iosrjournals.org/iosr-jvlsi/papers/vol1-issue3/e0133237.pdf
