11 years agoAsync FIFO 2 Clock code advice - VHDL
Hi all, I want to ask if someone can advice me an Async FIFO with 2 clocks code in VHDL that works. I know Xilinx provide already build in FIFO IP core, but since I want possibility to mig...
11 years agoThanks for you answer. But I need the possibilty to use this code also with devices not from Xilinx or Altera. The second option have a problem that I can't really know if my code will be without errors or optimized. So I ask if someone have an opensource Async FIFO.
