Assembler does not generate programming files when it run in the compilation flow
I have a project that assembler does not generate programming files when it runs in the compilation flow and gives a warning that says "Can't generate programming files for the project because the encrypted source file cannot be located: "sdi_*.v"". The files it listed are added to the project(via .qip file)(it is a SDI v17.1 IP). If I run Assembler individually, it generates the programming files without problem and with no warning. I can make progress in my project but I have to run assembler again after every compilation.
I use Quartus Prime 17.1
How can I solve this ? I couldn't find any solution online yet.
- JoanneSinY_L_Intel
Can you share your design to help for further understanding?
Joanne
It has been some time but I didn't hear from you. Any updates ?
Joanne
- MMavi
Hi, Sorry, i forgot about this. It's been busy at work since. I still have the problem. I tried creating a new project but it didnt work either. If there is a work around or fix you can recommend. I can try them out. Thanks, Mehdi Sent from my Samsung Galaxy smartphone.
Can you try
Go to Assignments -> Settings
Compilation Process settings
Make sure "Run Assembler during compilation" is ticked.
joanne
- MMavi
Yes it is checked. Sent from my Samsung Galaxy smartphone.
- MMavi
I created a small Project that replicates the issue. I am sharing it in this thread.
Regards.
Mehdi
I am able to solve the warning and generate out the programming file by specify the verilog path for the file in QSF file
set_global_assignment -name VERILOG_FILE ipcores/gxb_txsample_2xhd.v
set_global_assignment -name VERILOG_FILE ipcores/hdsdi_insert_ln.v
set_global_assignment -name VERILOG_FILE ipcores/sdi_clocks.v
set_global_assignment -name VERILOG_FILE ipcores/sdi_scrambler.v
set_global_assignment -name VERILOG_FILE ipcores/fifo_4x20.v
set_global_assignment -name VERILOG_FILE ipcores/sdi_trsmatch.v
set_global_assignment -name VERILOG_FILE ipcores/sdi_megacore_top.v
set_global_assignment -name VERILOG_FILE ipcores/sdi_tr_gxb_interface.v
set_global_assignment -name VERILOG_FILE ipcores/hdsdi_crc.v
Could you try and see and tell me the outcomes?
Joanne
- MMavi
It worked. Also I specify the paths in .qip file of the SDI IP to not overcrowd the files tab.
Thank you.
Mehdi
