MMavi
7 years agoAssembler does not generate programming files when it run in the compilation flow
Hi, I have a project that assembler does not generate programming files when it runs in the compilation flow and gives a warning that says "Can't generate programming files for the project because t...
JoanneSinY_L_Intel
7 years agoHi,
It has been some time but I didn't hear from you. Any updates ?
Joanne
- MMavi7 years ago
Hi, Sorry, i forgot about this. It's been busy at work since. I still have the problem. I tried creating a new project but it didnt work either. If there is a work around or fix you can recommend. I can try them out. Thanks, Mehdi Sent from my Samsung Galaxy smartphone.
