MMavi
7 years agoAssembler does not generate programming files when it run in the compilation flow
Hi, I have a project that assembler does not generate programming files when it runs in the compilation flow and gives a warning that says "Can't generate programming files for the project because t...
JoanneSinY_L_Intel
7 years agoHi,
Can you try
Go to Assignments -> Settings
Compilation Process settings
Make sure "Run Assembler during compilation" is ticked.
joanne
- MMavi7 years ago
Yes it is checked. Sent from my Samsung Galaxy smartphone.
