14 years ago
An important warning confused me--tri-state nodes do not directly drive top-level
Hi all,
Recently I compile a project in Quartus 9.0 and make some changes.
The results comes out with some strange warnings:
Tri-state nodes do not directly drive top-level.
I look up in the project
entity bidir is
port(
clk : in std_logic;
enable:in std_logic;
data: inout std_logic_vector(7 downto 0)
end bidir;
architecture behavior of bidir is
component test
port(
datain :in std_logic_vector(7 downto 0);
clk : in std_logic;
enable :in std_logic;
dataout:in std_logic_vector(7 downto 0)
end component;
signal data_reg : in std_logic_vector(7 downto 0);
begin
u1: test
port map(
datain => data,
clk => clk,
enable => enable,
dataout =>data_reg --data_reg is tri-state register
data <= data_reg when (enable = '1') else (others = 'Z');
end behavior;
I simulate the code in the ModelSim platform and the result doesn't give such warning.
I'm not sure whether the warning will affect the real hardware function.
Could anyone give me some advice?(It's better not to change the codes)
Best Regards.
