14 years agoThanks a lot. The 'test.vhd' as list
LIBRARY ieee; USE ieee.std_logic_arith.all; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; ENTITY test IS PORT( reset : IN std_logic; clk : IN std_logic; enable : IN std_logic; datain : IN std_logic_vector (7 downto 0); dataout : OUT std_logic_vector (7 downto 0) ); END test; ARCHITECTURE behavior OF test IS begin process(reset,clk) begin if( reset = '1' ) then dataout <= (others => '0'); elsif (clk 'event and clk = '1') then if(enable = '1') then dataout <= datain ; else dataout <= (others => 'Z'); end if; end if; end process; END behavior;
