Agilex 7 I Series AGIB027R29A1E2VR0
This dev kit with the engineering sample part has reached end of life, hence the installer is no longer available.
You can still use the user guide for reference available on the website.
We recommend customers to move to the production samples.
For BTS, I will have to check with internal team, if we still have a copy of it, but cannot assure you on that.
- Bharadwaja1 year ago
Hi @Ash_R_Intel,
Thanks for the reply.
I accept the fact that it was an engineering sample, but to work with the user guide, I at least require the schematics for generating the QSF file.As per my knowledge, the QSF file of AGIB027R29A1E2VR3 may not be sufficient to run a code on AGIB027R29A1E2VR0, I guess.
Please do help me with the QSF file or schematics and also Board Test System Files (BTS).
Thanking you in advance.
