11 years ago32-bit adder Carry Look-ahead
I am new to Verilog and I am trying to implement a 32-bit adder Carry Look-ahead, but the output is incorrect. I included the simulation in ModelSim and my verilog code. https://www.alteraforum.com/forum/attachment.php?attachmentid=10447module adder(CarryIn, a, b, result, CarryOut);
input a, b;
input CarryIn;
output CarryOut;
output result;
parameter delay = 50;
wire p, g;
wire c;
buf# (delay) buf0(c, CarryIn);
genvar i;
generate
for(i=0; i<32; i++)
begin: CalculatePandG
and# (delay) myAnd(g, a, b);
or # (delay) myOr(p, a, b);
end
endgenerate
carry_lookahead myCarryLookAhead(p, g, CarryIn, c, CarryOut);
genvar j;
generate
for(j=0; j<32; j++)
begin: JoinedAdder
xor# (delay) Adderj(result, c, a, b);
end
endgenerate
endmodule
//CARRY-LOOKAHEAD
module carry_lookahead(p, g, CarryIn, c, CarryOut);
input p, g;
input CarryIn;
output c;
output CarryOut;
buf# 50 buf0(c, CarryIn);
genvar i;
generate
for(i=0; i<31; i++)
begin: CarryLookAhead
cal_carry myCarry(p, g, c, c);
end
endgenerate
cal_carry myCarry31(p, g, c, CarryOut);
endmodule
module cal_carry(p, g, cin, cout);
input p, g, cin;
output cout;
wire temp;
and# (delay) and0(temp, p, c);
or # (delay) or0(cout, temp, g);
endmodule Could someone help me to fix this problem? Sorry for my bad English! Thanks in advance.6 Replies
Hey,
i was looking for a similar code and i actually found this. i think it's a good idea to combine 4-bit-adders to get the 32-bit-input as required. http://verilog-code.blogspot.com/p/types-of-adders-with-code.html You'll probably need to change the code slightly to implement into your design. but it's a pretty good reference! hope this is helpful to you. thanks. - Altera_Forum
I have already solved my problem, but I truly thank you for your reply! :)
hie v1t0ry,
sure, no problem. could i suggest that you: a) upload your fixed code here? if it's not confidential, then it would be really helpful as well for other forum members if they happen to have the same problem and stumble across your code? =) b) also, if not confidential, upload a copy of the fixed / working code in the Share Materials section of the forum? http://www.alteraforum.com/forum/forumdisplay.php?f=16 just my 2 cents, to help each other out! take care and have a nice day! - Altera_Forum
This is my Verilog code of MIPS 32-bit ALU, which is able to perform 4 functions including addition, subtraction, exclusive-OR, and set-on-less-than.
I use the adder to perform both addition and subtraction. Hope it is useful for amateurs like me! :)`timescale 1 ps / 100 fs // DA Cau Truc May Tinh - Lab 2 - ALU // Ngo Dat - 11DT3 //32-BIT ALU module alu(Output, Carryout, Zero, Overflow, Negative, BusA, BusB, ALUControl); output Output; output Carryout, Zero, Overflow, Negative; input BusA, BusB; input ALUControl; wire c, Less, add_out, xor_out, Less_out, p, g, BusBinv; wire CarryIn; parameter delay = 50; assign Less = 31'd0; buf# (delay) buf0(CarryIn, ALUControl); genvar k; generate for(k=0; k<32; k++) begin: CalculatePandG xor# (delay) myXor(BusBinv, BusB, ALUControl); and# (delay) myAnd(g, BusA, BusBinv); or # (delay) myOr(p, BusA, BusBinv); end endgenerate carry_lookahead myCarryLookAhead(p, g, CarryIn, c, Carryout); genvar i; generate for(i=0; i<32; i=i+1) begin: JoinedALUs alu_1bit myALU(add_out, xor_out, Less_out, BusA, BusB, c, Less, ALUControl); end endgenerate buf# (delay) buf1(Negative, add_out); xor# (delay) xor0(Overflow, c, Carryout); xor# (delay) xor1(Less, Overflow, Negative); Zero_module myZero(Zero, Output); mux32x4_32 myMUX(Output, add_out, xor_out, add_out, Less_out, ALUControl, ALUControl); endmodule //1-BIT ALU module alu_1bit(add_out, xor_out, Less_out, a, b, CarryIn, Less, ALUControl); output add_out, xor_out, Less_out; input a, b, CarryIn, Less; input ALUControl; parameter delay = 50; wire bin, btemp; not# (delay) not0(bin, b); m2_1 myMUX0(btemp, ALUControl, b, bin); xor# (delay) myAdder(add_out, a, btemp, CarryIn); xor# (delay) xor0(xor_out, a, b); buf# (delay) buf0(Less_out, Less); endmodule //CARRY-LOOKAHEAD module carry_lookahead(p, g, CarryIn, c, CarryOut); input p, g; input CarryIn; output c; output CarryOut; buf# 50 buf0(c, CarryIn); genvar i; generate for(i=0; i<31; i++) begin: CarryLookAhead cal_carry myCarry(p, g, c, c); end endgenerate cal_carry myCarry31(p, g, c, CarryOut); endmodule module cal_carry(p, g, cin, cout); input p, g, cin; output cout; parameter delay = 50; wire temp; and# (delay) and0(temp, p, cin); or # (delay) or0(cout, temp, g); endmodule //2-1 MULTIPLEXOR module m2_1(data, sel, y0, y1); output data; input sel, y0, y1; wire nsel, a, b; parameter delay = 50; not# (delay) not0(nsel, sel); and# (delay) and0(a, nsel, y0); and# (delay) and1(b, sel, y1); or # (delay) or0(data, a, b); endmodule //4-1 MULTIPLEXOR module m4_1(data, sel1, sel0, y0, y1, y2, y3); output data; input sel1, sel0, y0, y1, y2, y3; wire out0, out1; m2_1 myMultiplexer0(out0, sel0, y0, y1); m2_1 myMultiplexer1(out1, sel0, y2, y3); m2_1 myMultiplexer2(data, sel1, out0, out1); endmodule //32x4 TO 32 MULTIPLEXOR module mux32x4_32(Output, Add, Xor, Subtract, SLT, control_1,control_0); output Output; input Add, Xor, Subtract, SLT; input control_1, control_0; genvar i; generate for(i=0; i<32; i=i+1) begin : mux32x4_32 m4_1 myMux(Output, control_1, control_0, Add, Xor, Subtract, SLT); end endgenerate endmodule //ZERO FLAG module Zero_module(Output,Input); output Output; input Input; wire temp0, temp1, temp2, temp3, temp4, temp5, temp6, temp7, temp8, temp9; parameter delay = 50; or# (delay) or0(temp0, Input, Input, Input,Input); or# (delay) or1(temp1, Input, Input, Input,Input); or# (delay) or2(temp2, Input, Input, Input,Input); or# (delay) or3(temp3, Input, Input, Input,Input); or# (delay) or4(temp4, Input, Input, Input,Input); or# (delay) or5(temp5, Input, Input, Input,Input); or# (delay) or6(temp6, Input, Input, Input,Input); or# (delay) or7(temp7, Input, Input, Input,Input); or# (delay) or8(temp8, temp0, temp1, temp2, temp3); or# (delay) or9(temp9, temp4, temp5, temp6, temp7); nor# (delay) nor0(Output, temp8, temp9); endmodule // Test bench for ALU file module ALUStimulus(); parameter ClockDelay = 100000; reg BusA, BusB; reg ALUControl; wire Output; wire Zero, Overflow, Carryout, Negative; integer i; // If your register file module is not named "alu" then you will // have to change the following line in order to create an instance of // your register file. Also you must make sure that the port declarations // match up with the module instance in this stimulus file. alu alu1(.Output, .Carryout, .Zero, .Overflow, .Negative, .BusA, .BusB, .ALUControl); initial begin // Addition unit testing ALUControl=00; BusA=32'h00000DEF; BusB=32'h00000ABC;# (ClockDelay); // Should output 000018AB BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 00001339 BusA=32'h7FFFFFFF; BusB=32'h00000001;# (ClockDelay); // Should output 80000000, overflow, negative // Xor unit testing ALUControl=01; BusA=32'h00000DEF; BusB=32'h00000ABC;# (ClockDelay); // Should output 00000753 BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 00001331 BusA=32'h80000000; BusB=32'h00000001;# (ClockDelay); // Should output 80000001 // Subtraction unit testing ALUControl=10; BusA=32'h00000DEF; BusB=32'h00000ABC;# (ClockDelay); // Should output 00000333 BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 0000112F BusA=32'h80000000; BusB=32'h00000001;# (ClockDelay); // Should output 7FFFFFFF, overflow // Set Less Than unit testing ALUControl=11; BusA=32'h00000000; BusB=32'h00000DEF;# (ClockDelay); // Should output 00000001 BusA=32'h00001234; BusB=32'h00000105;# (ClockDelay); // Should output 00000000 end endmodule - Altera_Forum
thank u!!!
Some advice, if you want synthesizable logic I recommend avoiding delays in your RTL. That code will simulate fine but if you compile it for an FPGA you might end up surprised by the way it behaves in actual hardware.
