19 years ago
zd1211b can not work on uClinux-dist-20060803
Hi, hippo
I following your "WiFi" steps to try "GW-US54GZL" Wireless LAN USB Adapter on DE2 , bit it can not work.
display following message:
/>modprobe zd1211b
ZD1211B - version 2.15.0.0
vendor_id = 0053
product_id = 5301
USB 1.1 Host
Release Ver = 4810
EEPROM Ver =4810
Finsih download Firmware. Ready to reboot
PA type : 0
AiroHa AL2230S_RF
AllowedChannel = 000107ff
Region :16
usbcore: registered new driver zd1211b
/>iconfig eth0 up
/>iwconfig
lo no wireless extensions.
Warning: Driver for device eth0 has been compiled with version 20
of Wireless Extension, while this program is using version 17.
Some thing may be broken...
eth0 ESSID:off/any Nickname:""
NWID:0 Channel:0 Access Point: 23:00:31:00:00:00
Bit Rate:2.35631Mb/s Tx-Power=2356312 dBm Sensitivity:0/0
Retry:on RTS thr= 2356312 B Fragment thr=2356312 B
Encryption key:0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000
Power Management on
eth1 no wireless extensions.
I used NoteBook testing my Lab's wireless LAN it is ok ,but on target board can not receive Access Point. maybe is driver version problem?
Please help me!
    Please check if you have loadable module support enabled in kernel config.
    And the wireless lan support, too,
    in zd1211 driver dir, make clean, and then make.
    I tested again, but there is no compile problem.
    --- Quote Start ---
    originally posted by hippo@Nov 7 2006, 02:19 AM
    please check if you have loadable module support enabled in kernel config.
    and the wireless lan support, too,
    i tested again, but there is no compile problem.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19247)
    --- quote end ---
    --- Quote End ---
    hi,hippo
    I enabled loadable module support and the wireless lan support in kernel config.
    When compiled zd1211 drivers have no problem.
    but it can not revices any APs.
    I think is the USB ISP1362 driver have some bug.
    I don&#39;t have DE2 board. And can&#39;t help to debug the driver.
    If you want , you may try to enable some debug messages.
    Hi ,hippo
    I try out the Usbhost on my DE2 board.
    I following your steps, but when I enabled "mount" command then compile it.
    It have an error.
    error message display following:
    os2-linux-uclibc/sys-include/linux/nfs_mount.h:11,
    from nfs_mount3.h:15,
    from nfsmount.c:51:
    /opt/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/sys-i
    nclude/linux/in.h:131: error: redefinition of `struct ip_mreq_source&#39;
    nclude/linux/in.h:137: error: redefinition of `struct ip_msfilter&#39;
    nclude/linux/in.h:150: error: redefinition of `struct group_req&#39;
    nclude/linux/in.h:156: error: redefinition of `struct group_source_req&#39;
    nclude/linux/in.h:163: error: redefinition of `struct group_filter&#39;
    nfsmount.c: In function `nfsmount&#39;:
    nfsmount.c:237: error: `NFS_VERSION&#39; undeclared (first use in this function)
    nfsmount.c:237: error: (Each undeclared identifier is reported only once
    nfsmount.c:237: error: for each function it appears in.)
    make[3]: *** [nfsmount.o] Error 1
    make[3]: Leaving directory `/home/faye/uClinux-dist/user/mount&#39;
    make[2]: *** [mount] Error 2
    make[2]: Leaving directory `/home/faye/uClinux-dist/user&#39;
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/faye/uClinux-dist/user&#39;
    make: *** [subdirs] Error 1
    How can slove it ?
    Faye
    The defulat shell SASH, has a simple mount. You should be able to use it.
    If you still want NFS mount, use the "mount" in busybox.
