19 years agozd1211b can not work on uClinux-dist-20060803
Hi, hippo I following your "WiFi" steps to try "GW-US54GZL" Wireless LAN USB Adapter on DE2 , bit it can not work. display following message: />modprobe zd1211b ZD1211B - version 2.15....
19 years agoThe defulat shell SASH, has a simple mount. You should be able to use it.
If you still want NFS mount, use the "mount" in busybox.
