19 years agozd1211b can not work on uClinux-dist-20060803
Hi, hippo I following your "WiFi" steps to try "GW-US54GZL" Wireless LAN USB Adapter on DE2 , bit it can not work. display following message: />modprobe zd1211b ZD1211B - version 2.15....
19 years agoPlease check if you have loadable module support enabled in kernel config.
And the wireless lan support, too, in zd1211 driver dir, make clean, and then make. I tested again, but there is no compile problem.
