19 years agozd1211b can not work on uClinux-dist-20060803
Hi, hippo I following your "WiFi" steps to try "GW-US54GZL" Wireless LAN USB Adapter on DE2 , bit it can not work. display following message: />modprobe zd1211b ZD1211B - version 2.15....
19 years ago --- Quote Start --- originally posted by hippo@Nov 7 2006, 02:19 AM please check if you have loadable module support enabled in kernel config.
and the wireless lan support, too,
in zd1211 driver dir, make clean, and then make.
i tested again, but there is no compile problem.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19247)
--- quote end ---
--- Quote End --- hi,hippo I enabled loadable module support and the wireless lan support in kernel config. When compiled zd1211 drivers have no problem. but it can not revices any APs. I think is the USB ISP1362 driver have some bug.
