triple speed ethernet upgrading to nios ii/f problem
I am working on a project on a DE2-115 board that involves both a NIOS processor and the triple speed Ethernet IP core , the problem is that nios ii/e processor works well with the mentioned IP core but when trying to upgrade the processor to nios ii/f it doesn't work and it hangs at the step doing the software reset to the PHY chip. Do anyone have the same issue, or have any suggestion for fixing this issue ? Thanks in advance and highly appreciate your response.9 Replies
Are the Nios II/f and Ethernet IP core running at the same frequency? If they are not in the same frequency, try adding a clock crossing bridge in between them.
Thanks mikedsouze for your reply.
Yes, they are working at the same clock domain (100 MHZ). Even when I applied the provided example by Altera " Using Triple-Speed Ethernet on DE2-115 Boards " it only works with the NIOS ii/e and doesn't work with NIOS ii/f. appreciate your help. - Altera_Forum
Can the system runs "Hello world" ?
Yes I can run the hello world in case if I bypass this step "phy software reset ", cause the program runs infinitely through the while loop of the mentioned step - Altera_Forum
Hi,Actually i've the same problem but with the DE4. The TSE Tutorial provided by Altera use the NiosII/s classic processor, but when it's upgraded to NiosII/f the same software application stall in PCS reset and MAC reset, so i made the configuration steps described on ug_ethernet.pdf (TSE User Guide) and neither worked. I'm trying to figure out where/what's the problem here too.
Thanks jnasselle for your update , I have done also several trials (putting a clock bridge between NIOS and TSE , clock crossing bridge ) but unfortunately it doesn't work.
anyway thanks again, I will keep trying, and pls let me know if you reach to anything regarding this issue and I will do the same as well - Altera_Forum
The solution was to disable the data cache of the NiosII/f :) - Altera_Forum
Hi jnasselle
Thanks alot, You really made my day :) I wanna be your friend ;) - Altera_Forum
Disabling the Data-cache makes the /f compatible with /s.
For compatibility between Nios II/s you will need t o set the following settings in Nios II/f: No Data cache No Tightly Coupled Data master Static branch prediction No MMU/MPU support Internal Interrupt Controller No shadow register
