10 years agotriple speed ethernet upgrading to nios ii/f problem
Hi, I am working on a project on a DE2-115 board that involves both a NIOS processor and the triple speed Ethernet IP core , the problem is that nios ii/e processor works well with the mentione...
10 years agoHi,Actually i've the same problem but with the DE4. The TSE Tutorial provided by Altera use the NiosII/s classic processor, but when it's upgraded to NiosII/f the same software application stall in PCS reset and MAC reset, so i made the configuration steps described on ug_ethernet.pdf (TSE User Guide) and neither worked. I'm trying to figure out where/what's the problem here too.
