10 years agotriple speed ethernet upgrading to nios ii/f problem
Hi, I am working on a project on a DE2-115 board that involves both a NIOS processor and the triple speed Ethernet IP core , the problem is that nios ii/e processor works well with the mentione...
10 years agoThanks jnasselle for your update , I have done also several trials (putting a clock bridge between NIOS and TSE , clock crossing bridge ) but unfortunately it doesn't work.
anyway thanks again, I will keep trying, and pls let me know if you reach to anything regarding this issue and I will do the same as well
