10 years agotriple speed ethernet upgrading to nios ii/f problem
Hi, I am working on a project on a DE2-115 board that involves both a NIOS processor and the triple speed Ethernet IP core , the problem is that nios ii/e processor works well with the mentione...
10 years agoThanks mikedsouze for your reply.
Yes, they are working at the same clock domain (100 MHZ). Even when I applied the provided example by Altera " Using Triple-Speed Ethernet on DE2-115 Boards " it only works with the NIOS ii/e and doesn't work with NIOS ii/f. appreciate your help.
