10 years agotriple speed ethernet upgrading to nios ii/f problem
Hi, I am working on a project on a DE2-115 board that involves both a NIOS processor and the triple speed Ethernet IP core , the problem is that nios ii/e processor works well with the mentione...
10 years agoDisabling the Data-cache makes the /f compatible with /s.
For compatibility between Nios II/s you will need t o set the following settings in Nios II/f: No Data cache No Tightly Coupled Data master Static branch prediction No MMU/MPU support Internal Interrupt Controller No shadow register
