10 years agotriple speed ethernet upgrading to nios ii/f problem
Hi, I am working on a project on a DE2-115 board that involves both a NIOS processor and the triple speed Ethernet IP core , the problem is that nios ii/e processor works well with the mentione...
10 years agoYes I can run the hello world in case if I bypass this step "phy software reset ", cause the program runs infinitely through the while loop of the mentioned step
