13 years ago
There are no Nios II CPUs with debug modules available
I am facing this problem for over a week now, where when i try to debug as nios hardware the following error message shows up:
There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a
new SOF file if necessary.
just to be clear:
i have downloaded the respective .sof file (with jtag uart, and a level 1 debug module enable) to the target board (cyclone 3 running at 80Mhz external clock).
the NIOS 2 processor has on-board ram, interval timer, PIO and a jtag uart.
the clock pin on the processor is directly attached to the 80Mhz external clock pin input, and the reset pin is connected to Vcc.
here is the HW configuration:
Target Connection:
JTAG cable:
automatic<currently: USB-Blaster [USB-0]>
JTAG device:
automatic<the device which has the processor>
Nios II Terminal commnuication device:
jtag_uart_0<stdin/stdout/stderr>
https://www.alteraforum.com/forum/attachment.php?attachmentid=7361
here is a screen shot of the processor:
https://www.alteraforum.com/forum/attachment.php?attachmentid=7362
with jtagconfig -n i got this:
[NiosII EDS]$ jtagconfig -n
1) USB-Blaster [USB-0]
020F30DD EP3C25/EP4CE22
Node 19104602
Node 0C006E02
Please advice.
