13 years agoThere are no Nios II CPUs with debug modules available
Hi, I am facing this problem for over a week now, where when i try to debug as nios hardware the following error message shows up: There are no Nios II CPUs with debug modules available wh...
13 years ago --- Quote Start --- this should be the mistake. Your CPU is in reset all the time if you put vcc to the reset! --- Quote End --- Actually no. For an unknown reason, usually the reset input to a SOPC system is inverted, as shown by the name reset_n, so connecting it to vcc is the correct thing to do. htio, are you sure you are using the correct .sof file? Don't forget that if you are in opencore evaluation mode, the result of the compiler will be written to a *_time_limited.sof file and not the usual one. Did the .sof upload occur without any error? Are you sure the FPGA isn't reset (failure in a power supply for example) and reloads another design from flash?
