13 years agoThere are no Nios II CPUs with debug modules available
Hi, I am facing this problem for over a week now, where when i try to debug as nios hardware the following error message shows up: There are no Nios II CPUs with debug modules available wh...
13 years ago --- Quote Start --- both run as and debug as are not working. How do i ensure the processor is running ? There are only two pin from the processor to connect which is the reset and clk pin, the reset is connected to vcc and the clk is connected to the external clk which is 80Mhz. (7W-80.000MBB-T as the oscillator) is there any other things i miss ? --- Quote End --- this should be the mistake. Your CPU is in reset all the time if you put vcc to the reset!
